Try to solve this one!
Ed
PCM power reset could be caused by a bad PCM power relay. Will disassemble relay and check contacts or replace. I have had relay issues before but not with the PCM.
"Vref": is that the FICM or system Vref? I have no injector codes or indication of a bad injector when the motor runs.
ED
Thanks for the reply.
ED
ED
on
ED
ED
The fact you dont have injector codes is completely meaningless, the fact you have a truck that resets the pcm when it happens means you at best would have a p0603, p1000, p2614 or p2617, p0344. Its restting and basicly ram memory.
I said nothing about a relay. I said the pcm is reseting from either a vref or injectior short. That is my uneducated guess.
you be able to see that on the SGII or would you need something with a bit
more power like a VCM with the data recorder dongle?
Also if it was an injector would that show up with VCM and recored?
Sean
on
If one were watching the Vref and it was the Vref that was shorting would
Sean
Sean
he he he. Yeah, that's a good one. Thanks for the humor this morning.
MisterDave2
01-17-2009 10:47 AM
