Squeaky brakes are embarrising
Every morning when i get in my 2011 F150 the brakes squeak? First is was only one or two resolutions but its getting worse and lasting longer? I had them checked when I had the tires rotated at 30,000 miles and the stealership said they rated an 8-10. The cleaned them but now the squeaking is lasting longer? Any ideas? The disappointing part was the shop manager said they all do it which I call BS.
My '13 did the same thing. You can remove the pads and rub them on your driveway to roughen them up.... worked for about a week on mine.
I ended up just ordering new pads and replacing them. Original pads still had about 80% of their life yet, could not tolerate the squeal.
All brakes make noise to some degree but in varying frequencies. When dust builds up and moisture collects when the brakes cool down you will hear noise.
If you are a DIY check the calipers for looseness or loose parts. Brake grease on the backs of the pad are a big help but will eventually wear out with dust/moisture.
My 09 Explorer makes loud noises with the brakes until they get warmed up. Both my vehicles are garaged when not in use. But dust still accumulates from normal wear and the road.
My F-150 hasn't started with brake noise. It only has 7500 miles on it.
Mine started the dance near 60,000 miles at expressway speeds and when I inspected the front rotors they were full of eggshell heat cracks. Installed Diamond groved and slotted rotors on all 4 corners and presto new brakes and nary a sound. It's is like show room new now. Recommend them. 68,000 on it now.
I had squealing and creaking and had the brakes done and the noises continued until I realized it was a dry ball joint. I would try greasing them if you can get to them and see if it may help if you haven't thought of that already.
I always back in and pull out forward. I've never had any sounds moving forward. The other day my wife drove the truck and pulled in forward. The next day when I backed out it made a strange moaning noise for a couple feet then stopped. I took it to the dealer ship and they said my brakes are still good.
