Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Old 11-17-2014, 05:40 PM
clevelandboxers clevelandboxers is offline
clevelandboxers is starting off with a positive reputation.
Lightbulb CHIRPING FROM UNDER THE HOOD
I have been searching for an answer from this site for (how to figure out)where a chirping sound is coming from underneath my engine hood.
I am not a mechanic and I do not often post on this site, but I think it was important to post this one time.
I parked my car one cold morning and when I started it up, it sounded like I had a chirping bird under somewhere under my hood. When the car warmed up, I noticed the chirping sound would lessen and often go away. I changed the serpentine belt, but the noise kept on. After reading various posts, I changed out the idler tension pulley and several drive pulleys (bearings, not the actual pulleys cause members gave me the correct bearing numbers to buy them and press them out). I then cleaned the serpentine belt and all the pulleys with brake cleaner and a soft Bissell brush, but noise was still there.
When I took off the serpentine belt to check the rest of the pulley's for wobble, I noticed my alternator was chirping also so I changed it thinking that the bearing was bad. Unfortunately, this slowed the problem, but did not fix it.
One of the members said that it might be an ac clutch bearing and to check it by pressing in the a/c button. If the noise stops, then it is the bearing on the a/c clutch.
I then bough the stethoscope from Harbor Freight to try to locate the chirp, but every time I got near the engine compartment, the chirp would go away.
Well, this did not fix the problem either.
I finally read a random post by a member who said to check the fan clutch bearing. I read up on how the fan clutch works, and how to diagnose a bad one. Everything I read showed me that I had a good fan clutch. Regardless, I took off the fan clutch and ran the car for about 2 minutes without the fan shroud, fan blade, or fan clutch and the noise was gone.
I then put the fan clutch on a vice and tried to spin it as fast as I could. Sounded like the bearings were going bad in one spot every time it went around, but I could not get it fast enough to get it to chirp.
I replaced the fan clutch about a month ago and the noise has not come back yet.
Just a though for everyone before spending tons of money on trying to find their chirp under the engine.
Old 11-18-2014, 10:32 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum and thanks for the info.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
Similar Threads
Chirping under hood Idler pulley- other? Dutch123 1978 - 1996 Big Bronco 8 10-19-2010 07:25 PM
Serpentine Belt Squeak Chirp Squeal Fox Fader 1968-2013 Full Size Vans 4 04-06-2010 11:26 PM
2000 XLT ...Chirping sound under the hood Junebug_ Expedition & Navigator 11 01-14-2010 07:14 AM
What is that chirping sound under my hood? MikeSDK 1999 - 2003 7.3L Power Stroke Diesel 6 07-21-2007 06:20 PM
Chirping, Squealing Sound ??? cperdue3 1978 - 1996 Big Bronco 2 05-23-2005 02:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
