Upholstery help
Upholstery help
I am working on recovering the bench seat in my 69 F100. Not knowing any better, I tossed the old seat covers without removing the j channels from the bottom part. I ordered a new set off amazon that came from acme upholstery. It does not have a j channel on it, only the plastic tubing to attach hog rings to. There are no places to attach hog rings on the back and front of the lower part of my bench seat. I finally found a place that sells j channels and they will be coming in soon.
Are j channels standard on all 67-72 f100s or did a previous owner have a different seat installed? Second, how do I attach j channels to the upholstery without a sewing machine?
The long plastic clip (I've heard called a j-hook, j-clip, or j-channel) runs on the front and back of the seat cover I removed. The sides of the old seat cover are attached with hog rings.
The new seat has the plastic tubing. I wonder if I could insert metal coat hanger wire where the plastic tube is and attach the long plastic clip to that with hog rings and attach it all to the seat frame.
Thanks for the input.
milkweed.gardener
09-10-2018 09:29 PM
gpewett
16
10-10-2012 07:01 PM
88grandmarquis
11-11-2009 12:47 PM
