transmission "grind" coming out of OD
Old 11-19-2014, 08:19 AM
05_AlexF150's Avatar
05_AlexF150
05_AlexF150 is offline
Originally Posted by bbender85
Dr. Tranny Instant Shudder Fixx
i haven't put it in yet, so i don't have any results to report just yet.
Thanks, I might get me some of that Dr. Tranny.
My rumble strip issue only occurs when I'm in tow. I hate the sound it makes when it's about to get out of OD.
Old 11-19-2014, 09:26 AM
bbender85's Avatar
bbender85
bbender85 is offline
yeah mine occurred not towing, but will be towing the boat all next summer so even if this fixes it for now i'm still going to do a fluid swap like Mark mentioned in the spring.
Old 11-19-2014, 09:35 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,573 Likes on 1,051 Posts
Originally Posted by SDElwood
I have the bucket above, gravity feeds it.
That should work!
I have the exact problem as you described.
Can I ask what brand or name of the friction modifier you used to have solve your issue?
Thank you.
I don't recommend adding friction modifier. I recommend changing all of the fluid, using MERCON V fluid. That fixes about 95% of the transmissions that have this problem.
Old 11-19-2014, 11:52 AM
05_AlexF150
If yours is making that sound now it will be worse when in tow. I suggest you should get yourself an Edge Evo programmer, I set mine for the tran's option and really like it a lot, nice and firm shifting plus fuel economy increased.
Please report back if fluid flush really does the trick. But IMO these transmissions are weak to say the least.
Old 11-19-2014, 03:12 PM
SDElwood's Avatar
SDElwood
SDElwood is online now
You need a buddy with a warm barn, hoist, beer fridge, and tools.
Old 11-19-2014, 09:45 PM
bbender85's Avatar
bbender85
yeah let me know if you come across such a utopia!
Old 11-20-2014, 06:54 AM
SDElwood's Avatar
SDElwood
I know of one, but sometimes it's hard to keep the putz's out.
Old 11-20-2014, 07:09 AM
bbender85's Avatar
bbender85
you said you had tools.. man you weren't kidding!
Old 01-15-2015, 11:12 AM
bbender85's Avatar
bbender85
thought i would follow up and say the additive has completely gotten rid of the shudder. still definitely going to change fluid come spring, but for now it is better.
Old 01-16-2015, 06:54 AM
SDElwood's Avatar
SDElwood
That's good news. The beer fridge and hoist will be ready in the spring!
Old 01-17-2015, 09:34 AM
05_AlexF150
Really! That's awesome and thank you.
How much of the Dr Tranny lube did you put in?
Old 01-19-2015, 07:34 AM
bbender85's Avatar
bbender85
the whole tube.. which if i recall was only 2 ounces anyways.
  #28
Old 01-21-2015, 08:50 AM
05_AlexF150
Thank you, thank you very much. I'll be putting a few ounces soon, I hope I will get the same result as you.
  #29
Old 01-23-2015, 12:25 PM
Moco4man's Avatar
Moco4man
Moco4man is offline
Think I might try the additive, shop just told me that a fluid change would do no good, need an overhaul and new torque converter at 169,000 miles
  #30
Old 01-23-2015, 01:00 PM
bbender85's Avatar
bbender85
for less than $5 it's worth a shot.
Quick Reply: transmission "grind" coming out of OD
