Issues with Riffraff Wheel!
I'm running a E99 turbo with a 1.0 turbine and since there is no ported housing to had that I know of for the 4 bolt compressor housing. I am running the stock w.w. and I think it is obnoxious. And after hearing some say that the 6/6 wheel is along the lines noise wise of a w.w. I decided to go with a BD billet 9 blade wheel in hopes it is quieter than the w.w. So hopefully I get the same effect as a 11 blade in a ported housing.
I know some of you guys like the whistle sound but it drives me nuts. But it is still only 1/2 as obnoxious as my old Turbo Coupe Tbird was but back then I was young and I thought it was cool. Now I don't want to hear the turbo I just want it to do it's job and make power.
I do only drive the truck when I want to have fun so I enjoy the the whistle, the rattle, and if it gets too bad, I have a button on my dash that will make all that go away.
I am tickled with it and all the other stuff I picked up. Hopefully I will be able to run it at the next Riffraff east to see the difference it has made.
Ryan
Ryan
My RR wheel is much louder than my old WW. It has a lot more whistle. I cannot speak to the E99/though I am 2003. I am also running the AFE 2 which has a box around it but is not totally sealed. The noise is the first thing I noticed with it. Especially towing in overdrive. Get above 8 psi and it is annoying. Downshifting takes care of it. The harmonics change or the engine drowns it out, either way the whistle almost disappears.
Chet thanks for pointing out the fact about the E99 air box. My E99 air box is junk! I have had to drill and wire tie the lid down to get it to seal. I would be willing to try a Late99 air box but I would not want to throw much money at since I have been trying to save up for a AIS. But something else always comes up and I ended spending it on that.
And good to see you in the 'Hood Peter! Taking a break from killing trees with Miatas?
Rick I agree and I disagree because there are actually many different factors that effect what style of blade will work in different set ups. For example you have a stock 99-03 turbo with a .83 turbine housing and using a stock single plane 9 blade wheel with a ported housing and not get surge. Joe is using a 11 blade single plane wheel with a ported housing and he has no surge issues. The reason the stock 5/5 W.W. cures surging is it moves less air than the stock 9 blade. It really has to do with the turbo mapping of how much air you are compressing and when it is being compressed. A dual plane wheel compresses the air at a different rate to keep from getting surge. Where a single plane stock 9 blade compresses more air and earlier in the mapping which is why it can cause surging. But in the case of the BD 9 blade they extend the tips and changed the pitch of the blades so it compresses the same amount as stock but a little slower rate which moves it up on the mapping. Now in theory the 6/6 dual plane wheel should move more air than the 9 blade and it does but because of the dual plane and the pitch of the blades it does so at a different rate to not cause surging. Now when you go with a 1.0 or 1.10 turbine housing you are lowering drive pressure so that too will change the turbo mapping of a compressor wheel. I am sorry if I am doing a poor job explaining it but that is because I don't fully understand all the variables that effect the mapping of different turbo set ups. But it is not as simple as a dual plane is better than a single plane compressor wheel. There are way too many variables.
Anthony Giovino
Ford Truck Parts for Sale
04-15-2017 07:50 AM
Mlarp
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
06-20-2004 01:40 PM
