newbe needs HELP cranking but wont start after it rains
Old 11-16-2014, 10:56 AM
mehigh's Avatar
mehigh
mehigh is offline
1990 F250 with a rebuilt 1992 302 HO
cranks all day long but wont turn over
everything acts and looks normal (fuel pump, warning/notification lights, etc.)
thought the problem was fixed when I replaced the ignition module (side of the distributor) after a new coil plugs wires cap rotor.
ran ok for a few weeks went start it up after the first heavy rain and same thing
where do I start to chase this down GEM? GROUND? EEC?
just so you know I am a novice so will need detailed instructions
Old 11-16-2014, 11:09 AM
Conanski's Avatar
Conanski
Conanski is offline
Go get a hair dryer and use it to dry off/heat up the ignition coil, if the motor fires up immediately you found the problem.
Old 11-16-2014, 02:01 PM
mehigh's Avatar
mehigh
mehigh is offline
Will try that
It is a new coil but I will try that thanks
Old 11-16-2014, 03:34 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
New does not make it a good working part, same for the plug wires.....el cheapos tend to be bad out of the box.
Andy's Beast
10-21-2014 07:43 AM
jones189
08-06-2009 09:16 PM
cajun1965
08-01-2007 11:42 AM
bountyhunterjp
07-31-2004 10:44 PM
bac047
12-12-2001 12:34 AM
Quick Reply: newbe needs HELP cranking but wont start after it rains
