Defroster won't drefrost a thing!
The blower is working a just replaced it last winter thinking it might fix the problem but it didnt. I can feel heat up by the windshield but just no current or breeze how ever u want to say it lol. My dad says i might have vaccum leak on the selecter controls that open the vents. Could this be the problem?
Thanks, John
Thanks, John
A vacuum leak will cause the system to default to defrost.
This is not your problem.
A pencil can get down in there and jam one of the doors open or closed...
The heater core or AC evaporator (if you have it) can be blocked with leaves and debris from the cowl on the back side.
This will cause a low flow problem.
Gotta say, my defroster is working great the past few days.
I find it hard to imagine taking the A/C out of a vehicle in Texas!
But then, while I live in a part of the country where we see from zero to one hundred, it doesn't usually stay at or beyond the extremes for more than a week straight.
Have you tried it with the recirc door open?
(is there a setting for "Max AC"?)
I took the A/C out because i cant stand not being able to see my engine. That is why new fuel injection engines drive me nuts! Along with the fact that i cant work on it in my own driveway. My A/C selector doesnt have a circulation button deal. Just has the slider for temp, fan, and A/C, defrosters, vent, mix, floor. Do you know what the little white tube that runs under the dash intp the selector board does? Mine is crumpled and falling apart.
Thanks, John
Thanks, John
Tony Ricci
08-08-2018 01:04 PM
JayzDaddy
10-03-2016 07:11 AM
