Disc brake conversion kits
If you use your truck like a car, or don't mind the slight downgrade, you could probably swap in a 99+ superduty van d60 rear axle. E350 and possibly some e250s (brad probably knows what the options were) had a full floating d60 with disk brakes.
I'm not sure if the track width is the same. Brad knows more about these things. Maybe he will add info.
I have been looking at this company for my 89 sterling. Good for 1981 - 1998 3/4 1 ton
Ford Truck Rear
Ford Truck Rear
Ford Truck Rear
Ford Truck Rear
Also would i have to get bigger wheels to accommodate for the calipers and what not?
Just so I don't measue the wrong things what all do you need me to measure?
Thank you much sir!
Thank you! Is it a worthwhile upgrade for the money.. ie: how much better braking is noticeable. I tow about 7000 lbs roughly but i have trailer brakes too, would i see a big difference do you think?
I've done lots of research on this and from what I have gathered, the best and cheapest solution is the following...
1.) Fabricate some dana60 alxe outer flanges.
2.) Disassemble your breaks and pull your axles.
3.) Cut the Sterling 10.25 flange off the outter ends of the axle tubes and weld on the D60 axle tube flanges
4.) Reassemble with 94-97 E250/E350 disk brakes. These have the cable activated inner drums brakes that you use for the parking brake. Some modifications will have to be made for the cable parking brake to work, but this is a MUST for those with 4spd/5spd transmissions and need a parking brake. People with AOD and E40D auto transmissions might be less concerned.
Also Eldorado calipers aren't growing on trees around here. E250/E350's are pretty easy to find at the parts yards. Eldorado calipers are harder to find (here anyway) at the parts yards.
Lastly you need to think about installing a brake proportioning valve. You truck is going to stop differently with the disks in back and you'll have to adjust the amount of braking you want to the rear of the truck now.
