can I do this?
There are 3 switches that all need to be closed (I think) in order to enable the rear wiper. There's a left liftgate ajar switch, a right liftgate ajar switch, and a liftgate wiper disable switch. It appears all 3 switches go to the same input of the Generic Electronic Module, so I'm not sure if that means 3 wires in to one terminal or if that means that you will have 1 of the 3 switches. Normally the service manual diagrams are quite good at identifying if any of the switches or wires are optional based on features/options of the vehicle. No such nomenclature on this diagram.
As to whether bypassing this will fix the issue or if you have the skills necessary to bypass the switch, I'm not able to answer if you "can do this".
-Rod
-Rod
DadOh1
03-11-2012 08:50 AM
FordPickup460
24
12-04-2004 02:18 PM
D Ray
08-19-2002 12:50 PM
