RABS problems
RABS problems
I just bought an 87 f250 with a 6.9 diesel and a c6 and now the rabs light and the brake light are both on all the time. I can stop and shut off the engine and when I start it the lights are off but as soon as I put my foot on the brake pedal both lights come on and stay on also the brake pedal is really hard like there is no power assist but the booster is working the truck does stop real good but its bothering me and I have no info as to how to retrieve the codes or what the codes mean! any help would be much appreciated. Thanks!
hmmm well how do u know your brake booster works ? and on theses simple brake systems u really dont need to know the exact codes cus there really are none. But things to check would be brake fluid level and condition of fluid because they can stick ur level sensor and make it think its low. And if those check out ok then u can check ur rear speed sensor on ur diff. Honestly if ur truck stops good then i wouldnt worry about it its a very simple set up
Received 3,089 Likes
on
on
It's not a PCM, It's the RABS computer and entirely independent of any engine management.
It is the RABS light and the brake failure lights that are on...
It is the RABS light that flashes when you ground the wire and turn the key.
Do you think I have an engine computer in my DSII truck Tom?
I understand what you're saying about a problem vacuum pump causing a hard pedal.
Hydroboost is always an option.
I have fixed it! I already had a new vacuum pump and a new master cylinder already and I found the wire that is supposed to be grounded to check the codes but when I grounded it all the light would do is come on and stay on and go off only when the ground jumper was removed so I went a little further and checked the fluid pressure at the rear brakes and there was none and not much at the RABS valve so I borrowed the RABS valve off my 94 F350 and bled the brakes. now I have no abs light and the brakes work perfect so now I have to get a new one for the 94
on
but i do know there is no way to pull codes from your 87 with a 460 either.
i can not see a 87 diesel having a ABS computer, because my 88 diesel does not have one. all it has is the valve in the frame that has been bypassed since the truck was a few months old.
no idea Jim, i don't know what a DSII truck is.
on
I CAN pull codes from my RABS computer Tom.
It's an entirely separate system from any engine management.
What do you think feeds a signal to the plug on the RABS valve located on the frame rail???
What do you think lights the bulb up on the cluster?
unscrewed the lines going into and out of the valve, and put a short line between them.
my abs valve had one wire on it that went to the light. the light would come on if there was a loss of pressure in the rear brake circuit.
it was about as basic of a circuit as there was.
The abs valve has four wires going to it.
on
You'll find that RABS, or ANY antiskid brake system for that matter, will always have an electronic controller as well as it's own warning light separate from the red brake warning light.
