Niks DIY E fuel, bellows, s366 and trans rebuild
#32
Hmm Black/silver would be pretty sweet looking! Especially when you popped the hood. I think I'll settle on straight black, keep it simple. Just gotta figure out how many straights, 45*, and if I'll need any 180* fittings to order. I figure about 20' of AN6 braided should do the trick, plenty left over for spare lines etc.
#33
#35
I will take a better picture for you where the bellows are placed on this set of up pipes, is right where the down pipe is supposed to go. Not complaining, but yes, I will like have to figure out another 1.5 inches of clearance to get the 3" in there, with the stock pipes I could easily fit a 4" after modifying the firewall as I will need to.
Not the gretest pic, but you can see the bellows hanging out right behind the head where the DP used to go. I can take a snap a picture of the top view if and PM it to you. It shows it much better.
#36
#37
The bellow is positioned where it is going to be (Passenger side?). This is all bolted up and positioned where its final resting place is. I have seen them with the bend as well. If the bellow were lower on that side (plenty of room to put it lower) Than the dp would be a breeze. Oh well.
#39
T-wood
02-27-2018 07:28 AM
92bruiser
11-04-2011 07:54 PM
flainn
06-22-2011 01:01 PM
