I noticed today my oil cooler is leaking a little oil. I remember reading that some brands of orings should be avoided. Rockauto has A set from Doorman with gaskets and all 4 orings for $25.79. Anyone know if they are ok?
I got mine from advance auto since i work there part time (14.5 years now part time wow). I got victor reinz orings and felpro gaskets and so far so good.
I wasnt looking really in the right place at RA, didnt see the victor renze option. I will probably go with them and the felpro gaskets. Thanks for all the input.
Is there a difference between the 1983 6.9 idi oil coolers I have heard that there are 6 O rings in my 83 but really don't know I can't find anywhere that has them listed?
I helped a guy put some on an 86. We went to a diesel shop because the two Ford dealers didn't have them. Got the o-rings and wow...they were $25-26 a piece! They were in motocraft
packs. Tried to get some to match at a rubber and gasket shop. He said that he had some but they wouldn't take the heat and break down prematurely.
That's a good question, I seem to recall reading that about the '83s.
And looking at Rock Auto now I see the gasket kits are listed for '83 to '94, but the O-rings only cover '88 to '94; so only the 7.3 on the o-rings. Which doesn't make sense unless they're just avoiding confusion because of the first year 6.9 so they're leaving the entire run of the 6.9 off??
They're just not showing O-Rings at all for any 6.9.
If I remember correctly, the man at the diesel shop said that the older ones had more o-rings. Not positive though. The 86 had 4. I have an E series manual and it shows more o-rings.
