does anyone know where to find some replacement door strike pins for a 04' f250? all four doors are a little loose. tried to adjust them but had so success.
Yep, it's probably not your strike pins. As the weatherstrip wears it no longer has the ability to maintain tension on the door. The popular solution for that is to use latex tubing to stiffen your existing door seals.
Is there trick for a sagging door? I have approx a 1/2" sag that requires a near slam to get it to lift and latch properly. I was going to shim the bottom latch a bit but thought I would check here first...
Saging door would be hinge and or hinge pins. usually better to replace the whole hinge unless they have the pin sleeves and i would do both hinges cause chanes are if they are wore that much then both are shot.
