Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Old 11-13-2014, 11:02 AM
RKTech RKTech is offline
RKTech is starting off with a positive reputation.
Changing torque converter
I have a 97 F-150 Supercab XLT, 4X4, 4.6L W, 4r70W with electronic Overdrive, manual shift transfer case. I need to remove and replace the Torque Converter. My question is: Would it be easier to drop the transmission and transfer case or pull the engine loose and move it forward to get at the torque converter?
It is shifting in and out of overdrive to third, and then back into OD, and back into third erratically and for no apparent reason. It is also slipping intermittently in first from a dead stop and locking all at once, shifts hard then. When I first drive it the OD light does not flash and the OD off switch works, once it warms up good it starts shifting erratically and the OD off switch starts flashing, then the off switch does not work. I did not get any codes returned on autozones little scanner and am taking it to the ford dealer for a full scan today to see if there might be any other damage or cause for this problem. The problems started when I blew a hose to the trans cooler in the radiator and lost fluid. I didn't notice the blown hose until it started slipping and pulled over, replaced the hose and fluid. Had problems ever since. I have cleaned the MAF sensor and replaced the ABS sensor in the differential so far. Any advice will be greatly appreciated!
Old 11-13-2014, 03:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It is easier to pull the transfer case and the trans then pulling the engine. Besides, it is good practice for after you have the new converter installed. You'll need to pull the trans to rebuild it because the torque converter is not you problem. Why do you think it is?
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Old 11-13-2014, 03:46 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Semper Fi MOFO!
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
thronsonskip
maybe reuse your converter instead of wasting money on a new one and spend that money on the rebuild.
__________________
7.3 powerstop rotors, coated calipers, pads, 6637 filter, FRX, HPX, cobalt gauges, riff raff boots/plenum inserts. alternator 1/30/2012 199226 miles. oil filter, pre&fuel filter 9/2014 226221 Miles.
Old 11-13-2014, 06:01 PM
Scan results from above 97 F-150
Ford Dealer's scan results came back. P0304, P0307, P0503, P1500. Misfire on cyl. 4 & 7. 2 codes for ABS speed sensor. Mechanic said I have worn clutches in the Differential resu;ting in metal filings in Differential fluid which is causing the ABS speed senor (which I already replaced 2 days ago) to read all over the map. I saw the scan graph and at a constant 50 m.p.h. the scan graph was all over the place. You guys were right about saving the money on a new torque converter. I am popping the pumpkin cover off (9 bolt limited slip, 3.55 gears), cleaning with Brake parts cleaner, Put back together with Black RTV for gasket and refilling with new 75-140 full syn gear oil and Ford OEM Additive Friction Modifier. Will post results later. Thanks for the replies, I have been out of work for some time now and have a job waiting once I can get this truck back on the road!
Old 11-13-2014, 06:50 PM
ABS sensor reading incorrectly due to metal filings in differential lube or wiring to/from ABS speed sensor.
Old 11-13-2014, 07:35 PM
Quote:
Reusing an old converter on a fresh rebuild is a good way to need a second fresh rebuild. Never use an old converter on a new trans.
__________________
Mark
Old 11-13-2014, 10:02 PM
I agree Mark. If I have to rebuild the trans on this truck it will probably end up getting sold for a Mud Truck. Other threads indicate my problem could be a loose valve body, OD shift solenoid and or snap ring or the torque converter clutches are fried. I'll clean and refill the differential first. If that doesn't work I'll flush the trans, drop the pan and check valve body, new filter and fluid. It probably needs that anyways. Thanks!
Old 11-14-2014, 12:38 AM
Skip1970's Avatar
Semper Fi MOFO!
thronsonskip
what about if you flush the old converter out good with it running before removal?
__________________
Old 11-14-2014, 10:12 AM
Skip. I plan on flushing the whole trans, changing the filter and refilling with fresh ATF anyways, after I flush the differential and before I take it back to the dealer for a second scan.
Old 11-14-2014, 11:22 AM
You still stand an excellent chance of destroying the new transmission. If you insist on reusing and old torque converter take it to a trans shop and have them cut it open and rebuild it.
__________________
Mark
Old 11-14-2014, 11:25 AM
Quote:
That is a possibility.
OD shift solenoid
There is no OD shift solenoid. There are two shift solenoids and they control all of the shifting. They are called SS1 and SS2, no OD shift solenoid.
No, that won't cause any of your issues. It is NOT the torque converter causing these problems.
__________________
Mark
Old 11-14-2014, 01:15 PM
Skip1970's Avatar
Semper Fi MOFO!
thronsonskip
whats the price on a new convertor?
__________________
Old 11-15-2014, 12:12 AM
mark_5102 mark_5102 is offline
mark_5102 is starting off with a positive reputation.
i was quoted 150 at my local napa.
also to rktech i appreciate the shout out to kelsey from 2 stroke head . com and after reading your posts a bit i know you arent him. a touch misleading, i was about to pm you a question, but glad i read farther.
hope he doent come on this site and find his name is taken!!!
happy shreddin!!!
Old 11-16-2014, 09:46 PM
Here is an update. I took the differential cover off and thoroughly cleaned the inside of the differential, reinstalled cover and filled with fresh fluid and Limited slip additive. Great improvement! However after about ten miles the OD Off Switch light began flashing again but nothing else happened until it downshifted into third, then the switch did not seem to work to lock out overdrive. After pulling over and shutting the engine off, restarted with no flashing and except for a short slip coming away from a dead stop everything worked fine again for another five miles when I parked it back in my driveway. Should I take it back to the dealer for a second scan? Do I risk further damage continuing to drive it? What should I check net? I am stumped!
Old 11-17-2014, 10:24 AM
Nope that isn't me, I don't do 2 strokes.
Similar Threads
another five speed e4od, long post but i need help lablue96 1994.5 - 1997 7.3L Power Stroke Diesel 6 12-15-2011 07:40 PM
1990 E4OD, Hesitation or ??? rfmodulator 1987 - 1996 F150 & Larger F-Series Trucks 4 10-22-2010 05:56 PM
E4OD & P1728 Slip Code sunrack Clutch, Transmission, Differential, Axle & Transfer Case 6 08-24-2010 07:37 AM
Clubwagon Phantom 1968-2013 Full Size Vans 13 09-23-2005 08:33 PM
E4OD slips and whirs when very hot in 1st & 2nd otherwise normal at nominal temps moorefc Clutch, Transmission, Differential, Axle & Transfer Case 1 06-20-2005 09:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
