no heat
I'd have that passenger door checked----surely its at fault here for no heater blower right?
There are several parts associated with the heater blower operation so you'll have to diagnose this in order to effect a repair. As we don't know your level of mechanical skill this is most difficult.
The blower switch, resistor network, fuse/relay and of course the blower motor itself can be the problem here; any or all of these can and do cause this condition.
A simple and fairly easy test is running a 10 gauge wire directly from the positive battery terminal to the blower motor terminal. If it works then you have a problem upstream in the control circuit.
pancake52
02-18-2018 11:55 AM
SportTrac1725
01-30-2013 01:11 PM
jds84
01-11-2011 09:39 PM
