Australia Chapter Join Chapter , Leader: ChunderDownUnder
LED Projectors
Old 11-23-2014, 03:47 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yes , i'm waiting on the new bulbs and will try it in the housings first.
If you look at the photos i posted you will see the the new housings are flat on the backs so i might not have to cut the header panel.
  #32
Old 02-09-2015, 05:26 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Blue, any news on the Projector project?
  #33
Old 02-09-2015, 01:41 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
I just heard the other day from my friends across the street that their son got a ticket for his recessed LED Projector lights because the local police said they were "BLINDING"
What you've got there I doubt we could get away with over here at all...
  #34
Old 02-09-2015, 03:16 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Greywolf , I'm not sure how I'm going to be as far as the law is concerned here , time will tell .
The reason I'm going to change them is because i have HID's fitted in the new style housings now and they are blinding to oncoming traffic, and also they don't through a good light spread.
SSSimon, no i haven't started the fit up yet I've had a few other projects that have taken priority, will be on the list next.
  #35
Old 02-09-2015, 06:07 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
So you're damned if Y' do or not....
  #36
Old 02-09-2015, 07:47 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yeah I'll fit them and give them the test if there blinding I'll pull them back out and fit LED's in the housings i have now.
Just the lighting on these trucks are crap!
You have to wonder why Ford would build such a nice truck and fit crappie lights in them.
  #37
Old 02-11-2015, 06:23 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
I haven't yet come up with a headlight system that I want to take on the road in my "TEST VEHICLE" (1993 Suzuki Swift project) but I had some fog and driving lights on the Ranger before I went into it wholesale with the V8 swap.
I guess I annoyed someone around here locally because I found my road and fog set obviously kicked apart by someone twice after stopping at a local store. Pretty sure I know who the culprit is too, they drive a ragged piece of crap GM and one of them in it flipped me off one day even though I don't know them.
I still see a red haze in front of my eyes when I think about them... Two guys, one is an obvious drug derelict
I've been thinking recessed mounts so they can't be got at, and possibly a fabricated 'tunnel' for each to be mounted low and back from the bumper so that at close range they can't possibly interfere with anyone coming the other way.
  #38
Old 05-14-2015, 06:42 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Update - Projectors lights (hid's) are in place, i bridged a diode across from low beam to high beam so i don't get light drop out as you mentioned Simon.
This shows the diode from LB to HB
I haven't road tested the light spread yet as I'm still playing with the PVH solenoid.
The housing fit was really good, i had to trim the header panel on both sides, i'll show that in the next post.
  #39
Old 05-15-2015, 05:44 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Looks a good fit. I'll be very interested in the light output and aimability. That is mainly what is lacking in the '05 lights my truck is running.
  #40
Old 05-17-2015, 04:13 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
SSSimon, have it all back together now will do a light output test tomorrow and up-date.
  #41
Old 05-18-2015, 04:36 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
I'm sure that if they're aimed correctly and you have a responsible set of HIDs in there then you should be right.
Police generally only target on people when this is a real problem. Personally I wish they'd chase more people driving vehicles with bad headlights. Half the drivers here seem to need their fog-lamps on no matter what the conditions. You just about need sun glasses to drive around here at night time!
  #42
Old 05-18-2015, 06:58 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
They do that in the daytime here.
  #43
Old 05-19-2015, 08:13 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Light test up-date,
This is the first set up , I'll leave them like this until i i check them out at night , but looks okay from here.
The fit of the light housings is quite good for the price and the build quality is good too.
Side angle
  #44
Old 05-19-2015, 08:59 PM
BigF350's Avatar
BigF350
BigF350 is offline
Thanks for posting the results. The lighting pattern is surprising (not in a bad way) - most HID's have a "flat" beam, but it looks like these kick up on the passenger side like regular halogen setups.
  #45
Old 05-19-2015, 09:24 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
When i first set up the lights i drove the wife's Hyundai Sonata in the workshop and set her lights on low ( stock projectors) and marked out the light pattern on the white paper (test wall) and the pattern is identical to her's , so i thought with the cut off being the same it was okay.
I have yet to drive in the dark yet, or test the lights on a good wall to see the pattern .
BigF350, the lights in your truck are projectors so, does the cut off run to the left side or right ?
Quick Reply: LED Projectors
