NP435 Help!
The couple times I've pulled the top cover off a trans I've had it in neutral. This was for a ZF5, which had a ball on the bottom of the shift tower that fits into a socket on the piece that pushes the shift rails around. I'm not sure what the inside of a NP435 looks like, but I'd imagine there is some sort of similar arrangement.
It shouldn't so much matter what gear the trans is in as long as you put the end of the shifter back into the spot its supposed to fit in.
M998
01-05-2008 02:52 PM
ncranchero
03-11-2006 09:51 PM
