How to use a Hot Flusher machine on the Torqshift as a fluid exchanger @ SDutyS
Anthony's got a hot flusher machine here at SuperDutyService and hasn't had time to figure out how to use it on our trucks as a fluid exchanger. I've been tasked with figuring it out and my truck gets to be the Guinea Pig.
Hot Flusher(the company) says that at the machine Can Not and Should Never be used in-line with the transmission. Especially because of the high pressure reversing flow cycles it does. I can understand if there are any one way valves that this would be a bad idea.
Need input from shops that are using the Hot Flush machine, or Mark Kovalsky.
1. Where it should be connected? (We are thinking post ext filter, right before it hits the cooler)
2. Should the reversing cycles be disabled to mitigate damage to the tranny?
Let's figure this out so Anthony can start doing hot flushes.
According to their web page, Hot Flusher makes flushers for oil coolers and heat exhangers, not transmissions. Based on that alone I would not use it on a transmission until I had a documented process and procedure from the company that makes it.
In Japan you get hot flushes on the toilets. You also don't use them on transmissions...
Brian
Brian
Well I think that this is almost the same thing you have on your hands now.
https://rotunda.service-solutions.co...?itemID=109966
Sean
Sean
