I have a 73 hi-boy and wonder if 37" tires will fit on it? If not what are my best lift options to get them on there? And where to purchase it at?
Thanks!
Tim
yes they will but they will be close, depending on how your springs are..they make 4 inch lift springs for the front, and you can do a shackle flip for the rear like i did.. or you can just do like a 2 inch body lift then add a leafs..either way you might have to figure out shims for the front and rear end to correct the drive shaft angles..body lifts are easyer...people who say body lifts are bad dont know what they are talking about...anything under 4 inches is fine for a body lift..as long as your cabmounts and floor of beds are ok and not rotted out.... and its nice to change a starter or do header gaskets in between the fenders instead of reaching over and under the truck..
i have my links on my other computer but ill send you the link of the 4 inch springs,..not sure if you wana do body lift or a suspention, not sure what ya wana do with the truck..sounds like a cool truck tho! i have a 76..oh and one other thing how wide are your tires?
