12.2 mpg
I'll try that cause I'm gentle with the peddle
Start with cheap simple stuff that will cause a drag. I assume you are calculating mileage by hand, not the onboard display.
If 4X4, make sure front hubs are not locked
Chock wheels, put in neutral, and jack up 1 tire at a time....check for rolling resistance. (could be sticking caliper)
Might check in your state chapter to see if there is a member near you that might have an AutoEnginuty with the Ford enhanced bundle. He/she should be able to run a couple of diagnostic tests and check for codes.
Arizona Chapter - Ford Truck Enthusiasts Forums
Might cost you a cheap lunch or couple of cold beverages, but it's allot cheaper than the dealership. It was how I found my last two cracked injectors. As far as 12 mpg; I only get that kind of mileage when I'm dragging the 5th wheel at 70mph in the hills. You've got something going...too bad your 10-12 hours west of me.
