1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2 questions
Old 11-12-2014, 07:30 AM
250randy's Avatar
250randy
250randy is offline
2 questions
I am a newb & not a tech; I have 2 questions re; f250 5.4 2v
1. I have 2 fuses under dash that are stuck; trick to remove????
2. want to buy a cheap scanner; since I am not a tech or pro won't a $40(ebay or walmart) work for pulling codes & removing them???
thanks randy from texas
Old 11-12-2014, 07:50 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
1. Pliers and prayer (that you don't break anything).
2. If all you want to do is read and erase codes, a cheap reader will do that but nothing more.
Old 11-12-2014, 08:12 AM
250randy's Avatar
250randy
250randy is offline
thanks for the quick reply;
1. tried needle nose pliers yesterday; gently & wiggling etc; no luck ; the front clear medium size fuse doesn't show to be blown
maybe leave well enough alone but if they got hot enough to melt or "weld" their selves then they should be bad
2. if I upgrade to the $70-100 scanner what will I accomplish?
Old 11-12-2014, 08:29 AM
phillips91's Avatar
phillips91
phillips91 is offline
If all you want is to read or remove codes then just about any advance auto or AutoZone will do that for you for free.
Old 11-12-2014, 10:23 AM
250randy's Avatar
250randy
250randy is offline
thanks Josh
but here in texas because of lawyers & epa test they wont remove codes; maybe not everywhere is like that
Old 11-12-2014, 03:47 PM
phillips91's Avatar
phillips91
Originally Posted by 250randy
thanks Josh
I guess it varies by state. I always got mine checked and removed at advance, so I figured they all did it.
commandersander
15
06-07-2023 07:55 AM
renoduckman
03-24-2012 12:03 PM
devolic
13
07-05-2010 02:50 PM
dbu8554
1997 - 2003 F150
03-08-2009 09:47 AM
Quick444
02-19-2009 09:58 AM
Quick Reply: 2 questions
