where to buy an oil temp pigtail
Hey guys. I'm having a tough time finding an oil temperature sensor pigtail. It's the same as the coolant temp. I had some bare wires on mine and I've already cut it off.
Can someone point me in the right direction? I don't know that ford carries one .... at least the dealer said they didn't. I've had one shipped to me only to discover it don't fit.
Thanks
Bryan
Thanks
Bryan
Alliant Power Part# AP0056
GM part number 88953310 will work great if you break a tab off (I think these are available in the Auto Part stores - for perhaps a quicker/cheaper solution)
http://thedieselstore.com/catalogsea...q=EOT+pigttail
http://thedieselstore.com/2-wire-pig...-f-series.html
Edit -
sorry Money-Pit .. I didn't see that you had already posted the AP part #
Edit -
Here is a pic of the GM connector (OReilly's)
ACDelco PT1529 - Connector | O'Reilly Auto Parts
I have not used it myself, but was told about it. You might take the sensor to OReilly's and get a 1st hand look.
If you can wait it looks cheaper for the AP connector.
Here you go.
http://www.ebay.com/itm/281397979894?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITOr
http://www.ebay.com/itm/271529897911?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITEDIT : This guy is someone that Diesel Tech Ron happens to like. He has a lot of things a 6.0 owner can use.
Sean
Sean
Here you go.
6 0L Powerstroke Oil Pressure Sensor Switch Connector | eBay
Or
Standard Motor Products S940 Oil Pressure Switch Connector | eBay
Sean
Or
Sean
That is not what he needs
OOPS
Here is the right one.
Same guy that Ron uses
http://www.ebay.com/itm/03-10-6-0L-POWERSTROKE-COOLANT-OIL-INTAKE-AIR-TEMPERATURE-PIGTAIL-/281484171567?pt=Motors_Car_Truck_Parts_Accessories&hash=item4189c3992f
I had my pressure one come apart and was in a hurry when I posted this one.
No real excuse for that mixup. Anyway check this seller out for his other 6.0L
connectors. He has quite a lot to pick from. Also one that he has is this little goodie.
http://www.ebay.com/itm/6-0L-7-3L-PowerStroke-High-Pressure-Oil-Gauge-Wiring-ICP-Test-Harness-/271432624076?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f32a527cc
Would come in handy for watching ICP voltage.
Anyway sorry about the mix up.
Sean
Sean
dizzyfingers03
03-21-2014 02:22 PM
