Does anyone know how to keep the gas from evaporating from the float bowl of a Holly 1904 carb? I don't see any evidence of a leak but after several weeks of none use the gas is gone. The bowl has a glass cover so it is very easy to keep track of the gas level. I don't think the gas should evaporate or leak out that fast. Any thoughts?
"Several weeks" I would consider normal. If leaking down overnite, then I would suspect an internal crack leaking into intake. Having the glass bowl just makes it more evident.
