4x4 gear oil
4x4 gear oil
Just what exactly is this? Something special or ordinary gear oil by just another name?
I'm wanting to change the front differential fluid on a '95 F250 4x4. Front axle is a Dana 50 TTB. Owner's manual says "4x4 gear oil".
I get wild search results without any solid answers for my specific application.
Here is a link to all of the different kinds of transmission fluids Ford uses. At the bottom, under the type F tranny fluid picture is a link you can use to look up your vehicles Ford fluids by VIN #, to see if there has been an update on the recipe.
Once you have that, you can cross reference other manufacturers p/n, if you can't find the Ford product you want, so you get a recipe thats friendly with your trasnsfer case metals, seals & gasket material. Motorcraft® Transmission Fluids ? The Official Ford Parts Site | FordParts.com
Transfer case fluid is what you want I believe. There is more info down in the 6 & 7 notes on this page in the axle & tranny lube charts. GL-5 axle lube shouldn't go in a transfer case if it isn't specified, as the sulphur phos ad pack might not be metal, seal, or gasket friendly. The specified viscosity range in our manual is there for a reason, imo best for us to adhear to it. If you have a limited slip differential, it also might call for the specified friction modifier xl what ever is specified for you to also add to your differential lube. https://www.fcsdchemicalsandlubrican...n/quickref.asp
Most front axles I have looked up call for 80w90 so 75w90 would be just fine. I put 75w90 full synthetic in my front diff as an upgrade. I like to use 75w140 in the rear diffs even if they call for 80w90. I also prefer to use full synthetic gear lubes. Just personal preferences but I remember an owners manual for a GM truck I owned that spec'd full synthetic as lifetime fluid(unless submerged in water) or change conventional 80w90 every 30k miles.
LinwoodP350
08-09-2016 11:17 PM
anojones
04-10-2009 03:57 PM
andrewasl
08-15-2005 02:38 AM
