I just got some VHT nightshade lens tint stuff from Oreillys and put on two thin coats. I didn't spray the clear spots for my reverse lights because there isn't much light there to begin with. I also put in all LED bulbs so if I lost much brightness j gained it back and then some
I've read that the VHT Nightshades fade pretty quick, have you had that problem with yours?
Well I thought I broke the pull handle inside the truck for the hood latch, but the cable just came unhooked from the latch. So it turned out to be an easy fix.
