Australia Chapter Join Chapter , Leader: ChunderDownUnder
Boost Numbers
Old 11-11-2014, 02:32 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Boost Numbers
Lets see what every ones boost numbers are.
With the 38R WW2, RR intake , stock injectors, DP 60 HP tune, TM W/G actuator, i'm getting at WOT 30 psi 1200 degrees F egt's and in stock tune 20 psi , 700 degrees F at WOT.
Haven't tried with the 4 ton Caravan hooked up yet , that'll be the test.
What do you get?
Old 11-12-2014, 08:41 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
What's no one got a boost gauge.
Old 11-13-2014, 12:13 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Trucks not on the road at the moment.
Old 11-13-2014, 11:46 AM
BigF350's Avatar
BigF350
BigF350 is offline
Mine doesn't really count because it ain't a 7.3 - but I've dialed it back down to 25psi to save the turbo. Previously it could see up to 33psi. EGT's are 1200 going uphill with camper on back.
Old 11-13-2014, 01:09 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
That's interesting Adrian, a comparison between the 7.3 and 6.7.
Old 02-07-2015, 09:19 PM
Loaf4000's Avatar
Loaf4000
Loaf4000 is offline
hi Adrian
i have the same set up as you
not towing
80E
100k/6psi/1850rpm/flat road/egt 975f
when i hit a hill my egt come up very quicky
100k/18psi/2200rpm/egt 1250/ i am backing off then
i can hit 33psi in lower gears
when i two 2000kg
60E
MY egt climb even quicker
when i hit the hill
Old 02-11-2015, 01:44 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
40 PSI at WOT but I have big everything
lakewood
13
01-17-2020 04:14 PM
TexaSaiga
2017+ Super Duty
07-12-2018 05:29 AM
nossliw
43
07-15-2012 12:13 PM
desertrat64
09-29-2010 01:11 PM
hucka1a
10-28-2005 11:25 PM
Quick Reply: Boost Numbers
