Regen Notification
New to the Diesel world.
My 2012 F-250 Lariat FX-4
Love the picture of the DRW. I am brand new to the diesel market myself. I pulled the trigger and got me a '12 SRW 250 lariat. Only had it three days now, and just got snow on it for the first time!
Anyways, I have tons of questions about these diesels, I've heard so many good things about them and then I found a forum about people having regen problems and something about it dumping fuel into the left bank and having an engine rebuild and stuff. It's all scary. I want this truck to last me for a very long time so I want to take care of it like it's a child.
So my first question is this... how long does the regen supposed to last and do you have to wait until it's finished before you stop and shut it off?
My first one happened yesterday on the highway, I noticed the loud noise (louder than normal) and the little flash came on, but I had to park it about 5 minutes later. I didn't know if it finished or what. Appreciate all the advice. I agree about the great forum!
http://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1124/80-clifford_jr_snow2_2204b403d004bed25119b3499f3e2173 556d287c.jpg
You don't do anything wrong with shutting your truck off during a regen.
As for the regen issue you mentioned, its to do with the drivers side exhaust valves. If your truck makes excessive noise and/or vibrates during regen, you should take it to the dealer to get them replaced. There is a TSB for it.
You mentioned your truck is noisier during regen - it shouldn't be. Or at least I don't recall mine being noisier when I had emissions equipment on it.
They last about 5-10mins. If you monitor your instantaneous fuel consumption, you will see it pick back up once the regen is done.
It wasn't really noisy, just sounded like a loud engine fan starting up. Wasn't alarming, I was just thinking it was odd. Also by TSB does that mean that Ford will pay for the engine rebuild?
Last edited by Grizzly_70; 11-13-2014 at 08:36 PM. Reason: wanted to add a question.
If you let it continue, and it eventually drops a valve and you need an engine rebuild that is another thing entirely, and I'm sure dependent on if you are still within the powertrain warranty or not etc.
This 2015 is a little different than the 2012. The message is now "Exhaust Filter Overloaded, Drive to Clean". After clearing that and it starts a regen, the message "Cleaning Exhaust Filter" will stay on for the duration unless I hit OK and clear it.
For those with CTS, the soot level was up to 3.89 before I got the Drive to Clean message whereas the 2012 would always start exactly at 2.67.
Anybody got a link that works? Or can someone put it in dropbox?
#28
#30
Definitely more miles between regens. I don't track the miles but do run the same trips nearly every day. The 2012 would regen every day. Now it's every 4 or 5 days. This 2015 has a much wider soot level band than the 2012. I honestly think that the catalytic portion of the DPF was contaminated and not functioning as designed. Since the catalyst is what starts the fire that burns soot. The regen cycle was getting shorter and shorter. I'm not using any fuel additives in the 2015.
