Low Mileage oil change?
Hello all,
Bought a 5 gallon bucket and gallon container of rotella to do oil changes on the van and truck.
The truck hasn't seen 1000 miles of service this year, but its also been a year since I've done an oil change.
1) Should I change oil and filter or just oil? (installed fl1995 filter at last service)
2) Is a year interval ok or should I do it more frequently?
When its operated it does get driven at least 20 miles and gets a good heat cycle, so dunno if that makes a difference on the idi's
Thanks
Thanks
Correct, 5 gallon bucket of rotella plus another gallon = 24 qts, 2 idi's with PSD filters so I'll have a little extra for top up when necessary
Service manual? I figured it would probably be a good idea, BMW's recomend at least once a year if you don't hit the service due indicator.
I'm sure you'll be fine if you don't beat the truck with once a year oil changes at 2,500 miles a year.
milkweed.gardener
2017+ Super Duty
10-21-2017 05:46 PM
