Clear coating older paint
So a few weeks ago I was walking by my truck and accidently bumped a pad of steel wool on the old greyish blue paint and realized how much oxidation is really on that old paint..well...I ended up sanding the entire truck and turns out my truck is a very nice skylight blue with some of the paint flaking off to reveal a maroon colored primer and theres virtually no rust, maybe 3 small spots of surface rust on the entire body. The truck really has great character and Id like to leave it for now till I can paint it later. Would it better to put a clear coat on it to protect the paint/body or to just leave it the way it is?
Exactly what I'm wanting. One of the things I'm worried about is the clear coat won't bond correctly to the old paint and might flake off but I would really like some extra shine and protection
Here is a little help and direction from a thread yesterday I replied to. I excited to hear more.
https://www.ford-trucks.com/forums/1...ds-a-home.html
Remember that lacquer could react with catalyzed clear.
So I take it you are talking about original paint on your truck? Could the maroon primer be the actual red lead primer instead? If so then you probably have an enamel I am assuming. That being the case if you have a good solid adhering original and cured color coat, no cracking or chalking, then you could sand with 600 grit. From there you could apply a clear coat.
Just saw that stuff. Problem is they only sell it in 16oz spray cans. Not very practical and as such WTH were they thinking.
rods4life
03-04-2007 11:37 AM
