Fumoto Valve
Fumoto Valve
Found these Fumoto clips the other day , if anyone have a Fumoto valve on there truck these little units are great to stop an accidental opening.
This is the valve i fitted.
LC-10 | Fumoto Engine Oil Drain Valves
I have these valves on the landcruiser and the F250.
Great products, make oil changes much less messy.
I have even added them to the transmission and xfer case
on the Ford.
The xfer case tap has a 90 degree elbow on it, this was done
because the fuel tank is right up close to the outlet and I get
fluid all over it when draining the case, makes a big mess.
I had to get the xfer case valve from the US as it is not a size
carried in Australia.
I contacted the local Fumoto people and the guy I dealt with,
Jack Chan, was extremely helpfull offering to track down what I
needed and have it sent from the US, at no extra cost I might
add.
Great person to deal with, friendly and helpfull.
As for the clip, the first valve I bought from RiffRaff came with
one but the rest that I bought direct from Fumoto did not.
I have not bothered with the clip I have as I really doubt that
there is much likely hood of the tap being opened accidentaly,
they are quite tight.
I could be wrong, time will tell I guess.
on the Ford.
add.
Yes it does.
Contact Jack Chan
jack@fumoto.com.au
The guy is friendly and willing to help.
I am most impressed with the level of customer
service, I did not have to ask him to chase this
from the US, he offered.
Contact Jack Chan
jack@fumoto.com.au
The tank is a 250 litre monster.
Don't know the brand, there is no marking on it I could find to
identify it.
It was in it when I bought the truck.
Probably this one:
:: The Long Ranger :: Ford F250
They are the only company I know of that made aftermarket tanks on a larger scale, unless yours was custom made.
You could be right , i fitted this one F250 2001-2007 LWB E/Cab and it only holds an extra 125 l .
Probably this one:
My tank does not look like one of theirs.
You may be right about being custom made.
