Air Cleaner to Oil Filler/Breather - What are you guys doing?
Old 11-10-2014, 01:44 PM
bowtieman55's Avatar
bowtieman55
bowtieman55 is offline
Simply put, please advise lol...
Old 11-10-2014, 02:08 PM
Odie the Truck's Avatar
Odie the Truck
Odie the Truck is offline
I went to NAPA and they had some "breather hose" on a spool in the back.
It was about $2.
Old 11-10-2014, 02:20 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,675 Likes on 1,354 Posts
Any hose will work, though the rubber ones will usually get very soft if you have oil coming up into the aircleaner.
If you have a lot of oil coming up into the breather, you need to check your PCV valve for proper operation. If it's good, then your engine has a lot of wear.
Old 11-10-2014, 02:45 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I won't drive the truck if that isn't connected as the PCV system will be pulling dirty air directly into the engine. It wouldn't take much grit to ruin rocker arms, as that's the first thing the grit will hit. But then it'll move down to the innards of the engine and chew up bearings, etc.
So, I use a properly-size piece of hose from the filler cap to the air cleaner fitting. And, on Dad's truck with different valve covers and air cleaner that'll mean a trip to the parts store for exactly the hose Odie suggested.
Old 11-10-2014, 03:03 PM
bowtieman55
The truck isn't currently being driven. I'm trying to work out some kinks before I do start driving it. My issue so far has been that the breather filter barb is smaller than that of the oil filler barb in the valve cover. I'm working on a reducer deal right now.
Old 11-10-2014, 03:14 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I've been successful heating the hose to get it over the smaller barb.
Old 11-10-2014, 06:47 PM
Franklin2's Avatar
Franklin2
The fat silver thing he takes off to put the oil in(where the hose hooks) SHOULD have steel wool looking stuff up inside it. That works well enough to filter the air and keep grit out of the engine.
Old 11-10-2014, 07:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
^ This is incorrect. ^
Notice in 255/302/351W parts catalog pic (lower) that the smog valve (6A666) fits into the grommet (6A892) of the oil cap (6766) on the left (drivers side) valve cover.
Right (passenger side) valve cover has a grommet (6A892) and elbow (6767). Hose (6853) routes from elbow to nipple on air cleaner.
Old 11-10-2014, 08:14 PM
bowtieman55
LoL, it doesn't surprise me that it's an incorrect setup, Bill. It's not the original (or correct) engine, so I'm not sure what's been done and why.
I DO appreciate your input more than you know.
HOWEVER, this is what I came up with...
Old 11-10-2014, 08:18 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Looks good! Was that one item or did you add the piece that connects to the oil filler?
Old 11-10-2014, 08:20 PM
NumberDummy
It may look good, but it's not correct...see post 8.
Old 11-10-2014, 08:24 PM
bowtieman55
Gary, the 87000 hose is one I found (and hoped for the best) at Advance Auto. I cut about 3" off the air cleaner side of it. The hose on the valve cover elbow is a piece of 1/2" fuel/emission hose. Connecting them is a simple 1/2" to 3/8" coupler. It's nothing special, but it doesn't look TOO hack
Old 11-10-2014, 08:37 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Mine is on the driverside as well, should have been that way from the factor on mine as the orignal aircleaner does not have any holes in the back side for the passengerside valve cover to plug into. Now my 351W in my Mercury the passengerside hooks to the aircleaner for the fresh air and the PCV is in the driverside valve cover.
Not possible on my 302 in my '82 as the aircleaner does not have the provision on the back side for the breather filter to fit on the back side for the passengerside valve cover hook up.
As far as what I did, I just simply plugged a hose into the breather filter and stuffed it into the valve cover filler cap. Been that way for many years as I have not been able to locate the correct parts to do it the right way. Would have stole the same parts off a customers engine that was being sold but the aircleaner ended up being robbed by my boss for another customers truck a 1980 F150 Ranger.
Old 11-10-2014, 08:46 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
BTman55 - Thanks. No, it doesn't look too hack. And, even if the factory had the flow going in the other valve cover it doesn't matter as it will work either way.
Old 11-10-2014, 08:49 PM
bowtieman55
(kinda what I was thinkin')
Quick Reply: Air Cleaner to Oil Filler/Breather - What are you guys doing?
