Running out of fuel?!
I made that dumb mistake before with a working fuel gauge.
I put some diesel in the tank took it to the nearest fuel station and added some Diesel Kleen (optional) to help clean the injectors from whatever might have been sucked up from the bottom of the tank then topped her off. Nothing out of the norm and back on the road.
When you put fuel back in the tank and turn on the key, the fuel pump will end up pushing a lot of air into the lines from the fuel bowl. It will run crappy for 10-50 miles and then smooth out when the air is all gone. Before trying to start it up take the lid off the fuel bowl and fill it with fuel to reduce the time of no fuel to the injectors.
On a Superduty...
Fill truck with fuel.
Turn key and listen for fuel pump. It will turn off in 10-12 seconds, cycle key and listen again... Do this three or four times and crank.
Truck will fire right up.
OBS trucks use a mechanical fuel pump, bit more hard on the starter but...
OBS trucks I would fill the fuel bowl, crank for 10-12 seconds, fill the bowl again and crank 15-20 seconds... It should fire up at this point.
Not sure I agree with that, the pickup is always picking up from the bottom of the tank regardless of the fuel level and any crud would get trapped in the filter.
About 10 years ago when I was looking at the SD in my signature it was low on fuel. I wanted to take it for a test drive and it died on the way to the fuel station to get some fuel. It was running on fumes. We coasted into the station and the salesman put fuel in it. After a couple of tries, it fired right up and we went on the test drive. I ended up buying the truck.
Walleye Hunter
03-08-2014 07:37 PM
///M Puller
11-26-2007 08:12 AM
