1984 2wd 460 swap into a 1978 4wd F250 with the 400m automatic
So i've got a 1978 f250 4x4 with the 400 in it. the top end of the 400 is ok, but it needs new bearings. my plan was swap it out for a 460 out of an 84 f250 2wd. The 460 is a great running motor with relatively low miles. I know I need new engine mounts, but I was curious as to what else I really need and don't need. Will the alternator, and p/s pump brackets off the 460 work or do I need new brackets, also the 78 has factory a/c and I would like to keep the a/c. I've got both trucks ready to pull the motors out, I'm just weighing my options. I don't know if i'm better off just putting new bearings in the 400, or if I should do the swap. I really don't want to Get stuck spending a bunch of money doing a swap
Received 3,102 Likes
on
welcome to FTE. if you have the proper mounts and towers for the 460, it will be a direct blot in. you can use the 400 trans on the 460, they share the same bellhousing bolt pattern. AC will not be a problem either, just find an AC compressor bracket for the 460 and bolt it all together.
on
Lance-25_
05-11-2009 08:21 PM
