converting from efi to carburetor
Depends on the engine ... If I had to guess a 95 lincoln would be the 4.6 liter ... I think 91-92 would have been the last years of the 5.0..... The 4.6 is a coil pack motor and I've had little to no luck finding anything related to a carb swap on them .... Now it it happens to be a later p code head 302 5.0 found in the explorers or mountaineers. They are relitively easy to swap over just pull cam sensor and intake swap on a carbed intake and drop a distributor in ......
I think you can get a wiring harness that will run the engine and transmission if it is a SOHC 4.6 and a 4R70W transmission for around $900 dollars. Get a computer from a scrap yard and you will be much farther ahead. If it has high mileage the transmission may need work and also torque converter replaced. That engine also had 4 oxygen sensors and catalytic converters in the exhaust. I was lucky enough to have a complete car with everything I needed.
I'm an old school era OF, but I can't understand anyone wanting to take a late model ECU controlled EFI and electronic coil pack ignition engine and "convert" it to carburetor and breaker type mechanical distributor??? To me that's like replacing the touch screen on your cell phone with a rotary dial!
