I have a problem with my carb . Every time I accelerate quick it dies but when I do it slow it accelerates. I tried tuning it and didn't solve the problem. I changed the diaphragm and it still cuts out. I just don't know what.
If you can close the air/fuel screw idle jets in all the way and the engine continues to run with out stalling then it's a had main Power valve jet is bad.. Time to rebuild the carb.
Orich
If you can close the air/fuel screw idle jets in all the way and the engine continues to run with out stalling then it's a had main Power jet is bad.. Time to rebuild the carb.
Orich
I did when tuning and it wanted to stall. Im thinking of taking it appart and cleaning it.
Some Autolite 2100's had a accelerator pump check valve diaphragm by the main diaphragm. Looks like a birth control diaphragm for a rodent. Yours might be bad or missing. Note 9576 in this pic.
By the looks of it. I think I put the diaphragm facing the flat spot instead of the lil cylinder side. And I also put the spring the opposite side as well. Hope thats the problem
