84 f150 too rich or doesn’t run - Ford Truck Enthusiasts Forums
Old 07-17-2003, 08:31 AM
bobtu bobtu is offline
bobtu is starting off with a positive reputation.
A little background: I bought a 83 f150 with the 6cyl in it about a year ago. It has run fine… A little rich, but not bad... still ran good. I let the husband of my wife’s friend borrow the truck to haul off some yard waste and this jack a** loaded it up with a bunch of concrete and took it on the highway at about 75 mph. He said it lost power and started knocking real bad. After towing it back to my house, I dropped the oil pan and found 3 of the 6 rod bearings basically gone. I replaced all six and put the oil pan back on (now I got a small leak in the rear darn it... I'll fix it later).
Well, when I started it back up after that, it ran great (this is the first time I’d ever done anything on a car besides change the breaks/filters so I thought I was pretty cool)
So, I went on a test drive and it ran great for about 5 minutes, then progressively got worse… sputtering and wanting to die. I got back to my driveway and noticed that it was running very rich (thick black smoke and fouled plugs). This happened scenario happened a few times. Run good while cool and real bad when warm…
I figured it had to be the choke… well, it’s wide open when it is warm.
Then I noticed the carb was loose on the gasket and the metal tube that connects to the choke was rusted and broke off. That tube goes from the intake to the choke… some sort of vacuum controlled choke?? I picked up a new tube and connected the vacuum line back up along with new gasket and bolted the carb back down.
With all the vacuum fixed, the car now sputters and wants to die all the time.
I took the line from the intake to the choke back off and it runs good again…. Until it gets warm… then wants to die from the rich mixture… I thought about messing with the mixture screw, but it is capped on my carter YFA.
Any ideas?
Thanks for your help.
Old 07-17-2003, 01:13 PM
It is an 83 not an 84 - sorry
Old 07-17-2003, 09:12 PM
serving_time serving_time is offline
serving_time is starting off with a positive reputation.
First of all, that tube goes to the exhaust manifold, not the intake. The heat from the exhaust opens the choke. Look for a used carb somewhere on a truck that is running good, or even borrow one for a doy or two. Clothes pin the choke butterfly open and go for a drive. If this is a good carb and your truck is still running bad, than that last haul did more damage than you think.
Think about it. If the main bearings went from overheating, what else went?
Old 07-21-2003, 02:27 PM
The problem is, that the choke is wide open... and it stays wide open... it just runs real rich when warm...
I think I will make a trip to the junk yard this weekend and pick up a new carb... see if that works.
Heck... for $300 I could pick up a new engine and completly rebuild the one I have...
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 10:11 AM
Climatic choke operation - musings 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2013 06:03 PM
Is my choke working properly? 460 Fuel Injection, Carburetion & Fuel System 3 03-05-2006 01:18 PM
'84 F-150 Carb Problems JDemo-in-NC 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-21-2005 08:37 PM
Missing choke parts? 2150 on a '79 sdinino Fuel Injection, Carburetion & Fuel System 3 10-15-2003 01:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
