Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 04-10-2002, 10:24 AM
kwing kwing is offline
kwing is starting off with a positive reputation.
Idle air control question
Hi again Electric1. I've adjusted the TPS to .96 VDC closed, with the throttle plates just not sticking. As a side note, it shook when I started it cold this AM. I blew in the MAP sensor vacuum line to clear it out and then it started fine. After warmed up the idle is fine now. On a warm start the idle comes right down. When I shift to neutral and back to drive the idle stays put. Yeah! However, when I disconnected the IAC, the idle never moved. I checked voltage on the IAC and it is working (new unit last year and cleaned). You said something about closing the vent holes in the throttle plates and readjusting the plates and TPS and IAC after that. Was that on a V-8 or just for the I-6. My engine has 125,000 miles on it and is original. Thanks. Oh, by the way, the original reading on the TPS before I adjusted was .97 VDC closed (with the plates gummed up).
  #17 (permalink)
Old 04-11-2002, 11:18 PM
Electric1 Electric1 is offline
Electric1 is starting off with a positive reputation.
kwing, straight 300 6 cylinder, has the holes in ....some... throttle bodies, I have not seen the holes in all the 300 6 cylinder throttle bodies, MAP sensor line slightly clogged causes problems also like you found out, I'm glad I could help you find your problem and teach you about your ride, Electric1
  #18 (permalink)
Old 04-12-2002, 12:05 PM
stevieray stevieray is offline
stevieray is starting off with a positive reputation.
Well here's a new one, on me at least. I finally cured my erratic idle problem and did it for free. For some unknown reason I decided to take my MAP sensor air line off and when I did it dripped condensation. I just put it back on, started the truck and then pulled it partly off again, just enough to keep the engine running but also enough to suck the moisture out of the line, then I re-installed the line and VOILA! no more erratic idle! I just love these dumb luck fixes.
  #19 (permalink)
Old 04-12-2002, 02:43 PM
Rockstar Rockstar is offline
Rockstar is starting off with a positive reputation.
Tags
49 , air , control , explorer , ford , high , idle , motor , problem , problems , rpm , sensor , speed , symptoms , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
