2004 Engine 5.4 or 4.6? - Ford Truck Enthusiasts Forums
Old 07-17-2003, 07:39 AM
donybrk donybrk is offline
donybrk is starting off with a positive reputation.
Smile 2004 Engine 5.4 or 4.6?
I am buying a 2004 F150 Supercrew next month and can't decide on the 5.4 or 4.6 engine. I am not pulling anything heavy now but might need the power later and the gas mileage is the same on both engines. Any thoughts on the new 3 valve technology on the 5.4 or the current 4.6? Is it worth the $800 dollars for the 5.4?
Old 07-17-2003, 10:00 AM
Fat Mike's Avatar
Fat Mike Fat Mike is offline
Fat Mike is starting off with a positive reputation.
From what I've read, quite a few people have said that the power increase for the 5.4 is negligible due to the increased weight of the new trucks. Following that logic, it would seem the 4.6 would perform worse.
IMHO, you'd be better off getting the 5.4., but I suggest you test drive them both and see which would better suit your needs.
Old 07-17-2003, 02:50 PM
Thanks! It seems like I should go with the 5.4 because of the added weight, but the engine is not proven yet.
Old 07-17-2003, 10:07 PM
Lectrocuted Lectrocuted is offline
Lectrocuted is starting off with a positive reputation.
If it's any consolation a few big wigs are driving the 2004 to make sure it's ready. Must have a lot of faith in their engineers. LOL
Old 07-18-2003, 11:05 AM
RX 1 Liter RX 1 Liter is offline
RX 1 Liter is starting off with a positive reputation.
Go 5.4 even if you aren't going to be towing alot. I have 135,000 miles on my 4.6L 97 Supercab and I always wish I had the extra power. My 04 Screw will have it.
Old 07-18-2003, 12:02 PM
ktmguy70 ktmguy70 is offline
ktmguy70 is starting off with a positive reputation.
Not sure if Ford has their head on right sometimes, The 4.6 offers no mileage advantage over the 5.4, so im not sure why ANYONE would want this engine in their truck, I have one in my EXPY and PERSONALLY would like to shoot the guy who came up with the Idea for putting such a puny motor in such a large vehicle.
Lets Hope the new 04 is more ready then their hot to trot turblow diesel that they cant fix.
Ron
99 EXPY XLT
Old 07-18-2003, 12:23 PM
I am definitely going with the 5.4, for the one time cost it will be well worth the increased horsepower. I hope the tested the you-no-what out of this new 3-valve technology.
Old 07-19-2003, 08:07 AM
Classicdr Classicdr is offline
Classicdr is starting off with a positive reputation.
Honda has used the 3-valve technology for several years without any bad problems, so Ford should be successful as well.
Old 07-20-2003, 11:05 AM
garand garand is offline
garand is starting off with a positive reputation.
One nice thing about the three valve technology is that there are significantly fewer moving parts compared with four valve designs. Fewer moving parts means fewer things to break, so...
Old 07-21-2003, 09:56 PM
borderman borderman is offline
borderman is starting off with a positive reputation.
I would definitely go with the 5.4 liter because of the sheer weight of these new trucks. Even if you don't do any towing or hauling you still want to be able to get up to speed and merge with traffic without too much effort. My current ride is a 97 f150 supercab with over 150k miles on the odo and although I never tow or haul anything on a daily basis, the truck could use more power for passing.
Old 07-22-2003, 08:38 AM
Quote:
Not a good comparison imo.
Old 07-22-2003, 10:19 AM
lariatf150 lariatf150 is offline
lariatf150 is starting off with a positive reputation.
Ford has no plans to put a diesel in the F-150's (heard it on a Ford conference call available on their web site). A reporter asked and they said no.
The milage on the 4.6 and the 5.4 is teh same according to the info I've seen. I'm definitely going for the 5.4 for whatever more it costs up front. It will be worth it.
Old 07-22-2003, 12:39 PM
ExcellentRed ExcellentRed is offline
ExcellentRed is starting off with a positive reputation.
The 4.6 gets the same mileage because it has to work harder than the 5.4
800 bucks is definately worth it to have a bigger engine. It'll probably last longer too, since it won't have to work to its capacity all the time just to get up to speed.
Old 07-23-2003, 11:45 PM
455 Jet 455 Jet is offline
455 Jet is starting off with a positive reputation.
I tow my 19' boat with my 5.4 and my dad's 4.6. The 5.4 does a much better job at acceleration, pulling, less kickdown due to more torque, better traction (open vs. limited axles). The 5.4 does get worse gas mileage when towing, but for the gains in performance, its the way to go.
Old 07-25-2003, 06:44 AM
I believe the 5.4 is standard on the '04 FX4 and the Lariat
4.6 or 5.4? Bruker 2004 - 2008 F150 2 07-18-2015 08:02 AM
Engine swap 2003 expedition 4.6 l v8 too a 2004 f-150 5.4 v8 what can some one help Rezdoggsp Engine Swaps 0 11-01-2013 08:24 PM
5.4 to 4.6 engine swap almoststock 1997 - 2003 F150 4 12-01-2012 11:45 PM
Questions about 4.6 wa2be 2004 - 2008 F150 4 08-31-2009 10:55 PM
Where is the IAC located on a 1999 5.4 moedaddy 1997 - 2003 F150 3 04-13-2008 01:14 PM
Tags
46, 54, comparison, engine, ford, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
