OT but relevant, keeping grease guns from leaking?
Jokes aside, grease points are super critical, and they NEED lubed on a schedule, but it's a PITA and messy so it's easy to "forget". I just use a general all purpose moly chassis grease.
Grease Gun with Pistol Grip
Just your average manual pistol grip gun, mine is not Harbor Freight though, picked it up at the local tractor parts store sometime back.
Grease is a high temp tan colored grease, I have so many random brands and its been awhile since I changed it that I can't say what the brand is.
I use the green grease, and it doesn't drip or liquefy.
The common denominator here seems to be the type of grease used. Maybe? Because my Chinese junk gun doesn't leak.
Nature of the beast. So I buy an over $200 electric Lincoln, and there is
a puddle of oil in its case??? I will live with that, cause thats the best
thing I ever bought. (my woods are loaded with grease guns I flung)
another question>? how come every time you grab the grease gun its
empty, but still has a little grease in it. The electric pumps every drop
out. I guess the electric may be not for everyone, but we have a lot
of greasing 15 min electric over 1/2 hour with hand gun for a backhoes
2 zillion fittings....
sam
sam
I've cut a hole in the top of an old antifreeze jug and I let the whole thing set under the bench out of direct sun.
It never fails though, I go to pull the mess out from under the bench and the hose catches on something and whips around and slops a goop of grease on my forearm. Then you set the jug down so you can wipe your arm and the top heavy jug with grease gun poking out of it falls over and the oily drippings run out on the floor.
So, in the end, it would almost be easier for me to just hang it off the end of the bench to randomly drip on an old rag.........sigh
Bobby
Bobby
Elmo
I would be in a heap of trouble if my handle slipped. I take the head off and shove the body down in a bucket of grease, pull the handle back and locked. It sucks the barrel full of grease without any air. Then put the head back on and good to go. I think the grease is cheaper in the tubs and buckets.
Elmo
Elmo
#29
However, I used to fill grease guns direct from the bucket and one bump of the handle would puke a whole gun of grease everywhere! Which is one reason I use the cartridges now........
#30
OK, I think I learned something here. Maybe if I stop buying the cheap general purpose grease, my gun will stop dripping? Nice! Also, to solve my drip, I hang it on the wall with the edge of a crumpled up paper towel held between the body and the wall. The crumple is necessary so that the pt is 3 dimensional and the oil drip will hit it. The paper towel seems to control the drip by absorbing it until I need to grease something again. BTW, last year I bought a new grease gun and got one-hand squeeze handle. Much better than the two-hand lever model.
