49 f1 air deflector
Old 11-08-2014, 02:57 PM
1bikenerd's Avatar
1bikenerd
1bikenerd is offline
49 f1 air deflector
I have a 49 F1 and it's missing the under hood air deflector. I know there is a difference between the 6 cyl and the v8. I have a flathead v8 in mine. I have found two deflectors and I'm try to determine which one is correct. I measured the height of them and one is approx 6 3/8 wide (measured top to bottom) and the other one is approx 5 1/4 wide. Can anyone tell me which one I need?
Thanks
Dave.
Old 11-08-2014, 03:09 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
The V8 air deflector will have an R stamped deeply in the bottom corner. The six cylinder deflector will have an H stamped in the same place.
Mark
Old 11-08-2014, 03:16 PM
49fordv8f4's Avatar
49fordv8f4
It is stamped deeply enough that it can be seen from either side like the ribs that are stamped in it. I don't remember which side of the truck that it is on, I would have to look at mine. It is on the face on the lower corner next to were it bolts to the hood.
Mark
Old 11-08-2014, 03:18 PM
1bikenerd's Avatar
1bikenerd
Mark!! Thank you!!! ������
That was the info I need!!
Thank you again!!
Dave.
Old 11-08-2014, 05:43 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
V8 deflector is approximately 33.5" wide. 6 cyl is 2" shorter at 31.5" wide.
Old 11-08-2014, 08:40 PM
firstrider's Avatar
firstrider
firstrider is offline
Have an extra if you need one media , blasted , primed , painted gloss black w/ the seals applied . PM for more details Later ,Denny
Old 11-09-2014, 05:45 AM
49willard's Avatar
49willard
49willard is offline
Denny, May I ask what you used to fasten the seal to the metal? Did you use an adhesive, if so what worked?
Old 11-09-2014, 09:30 AM
firstrider's Avatar
firstrider
The wire staples were carefully removed , straightened & w/ the help of some black silicone adhesive were reinstalled to secure the seals on the air deflector .Use plenty of clothes pins for clamps .Just make sure any clothes pins with black silicone DO NOT make it back in the clothes pin bag .
firstrider
10-09-2009 10:04 AM
tyman
03-25-2001 07:09 PM
Quick Reply: 49 f1 air deflector
