2 Speed sensors? cruise and 4x4 INOP
fuse 20 was gone.
Is there a way to jumper the brake switch to check if that is malfunctioning?
If it is all normally open that would be great just unplug.
Not sure now the brake interacts with the 4x4,
That's my best guess. It may be right, half-wrong, or all wrong, but it's the best I can do without advanced info of the internal electronics. Fortunately, it's easy to check with a meter once you identify an appropriate test point.
Sorry, .I wasn't trying to step on anyones toes, I was just relaying a message from the ford technician I talked to. he said when multiple things go out like that, it is usually the gem model because it controls a lot of functions of your truck ie lights windows horn four-wheel-drive, cruise control, excetra.
on
on
UPDATE
FIXED
4x4 was the transfer case motor.
Cruise was bad connection at the recall mod at the master cylinder.
I had grabbed a clutch switch bypass plug from an automatic truck. initially that thought this was the issue, because the computer was seeing the clutch in AND out at the same time. Since I knew the switch was bad we replaced it. No effect on cruise then was able to see lask of proper brake signal.
Pulled the motor of the t-case and is was shot, t-case shifted fine by hand so replaced the motor.
Oil leak in the valley got really bad. It was the unserviceable plug. Got the kits from dieselorings.com fixed the plug and replaced all other o-rings. Oil leak gone clutch starting to come back in. Will probably pull trans and clean everything and turn flywheel. I replaced clutch with hi performance model and it has always slipped. The supplier claims the factory lywheel is concave and their clutch is made for perfectly flat. We did not know this, and flywheel looked super so we just reassemled.
Horn i have not got into.
Got 4 steel rims and 6 new treadwright bead to bead remolds in their warden II (BFG AT) tread. They look great cost was good and shipped fast. will start a thread on thse to track how they do long term.
FIXED
tigers2007
1999 to 2016 Super Duty
16
11-17-2012 04:49 PM
