Vacuum Wipers slow
Old 11-07-2014, 02:38 PM
Lewis1960's Avatar
Lewis1960
Lewis1960 is offline
Vacuum Wipers slow
Hi there,
I'm trying to fix up some little issues with my 1960 Ford F100. I have the original Vacuum wipers, the last owner put an extra canister in to help with the suction, but they are extremely slow. Is this normal, or should I be looking for an air leak somewhere? I know there are electric conversion kits out there, but the truck is in original condition and we want to keep it that way. Any advice?
Old 11-07-2014, 03:48 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
If they speed up when you let off the gas pedal they are working fine. Check rubber lines for cracks if they dont speed up.
Old 11-07-2014, 07:41 PM
spurredon's Avatar
spurredon
spurredon is offline
Originally Posted by Lewis1960
Hi there,
I love that kind of talk!
Old 11-08-2014, 07:28 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Does your engine have an original double diaphragm fuel pump that increases the vacuum signal?
Vacuum wiper motors have leather veins ( don't recall the proper name ) that dry out/crack and no longer seal. Have you tried lubricating all the linkage under the dash.
You could switch to electric and still be original, many had electric wipers, mine does..
Old 11-08-2014, 12:55 PM
Lewis1960's Avatar
Lewis1960
Thanks for your help. They don't speed up at all, all the hoses look new, but perhaps I'm missing something. I'll check more carefully. Have a good weekend!
Old 11-08-2014, 12:58 PM
Lewis1960's Avatar
Lewis1960
It looks like the hoses were replaced by the last owner. I think we may have to switch to an electric set. You can't always predict when it's going to rain and it's hard to drive without wipers. There is smoking of added on diaphragm that is supposed to help with the suction but I don't think it's working well. I'll double check all the connections...
Thanks!
Old 11-08-2014, 04:31 PM
economan's Avatar
economan
economan is offline
And remember if you do switch over to a set of electrics offa another truck to grab the whole linkage(s) as the vacs & elecs use different.
there are places that rebuild vac wiper motors for purists, but with the availability
of electric set ups why would you. Mine are the Bosch type I pulled em' offa a 59 f350 like 29 yrs ago never let me down yet.
Mikie
near Ottawa Canada
58 m-100 panel & 64 econoline p/u
Old 11-09-2014, 03:03 PM
Lewis1960's Avatar
Lewis1960
Cool, thanks, I'm stuck with what we've got for now as we are in Switzerland. If we change we'll probably have to buy a new kit from one of the auto suppliers like Mac's. Hopefully we'll pass inspection the way it is and hopefully it won't be raining the day of inspection. LOL, it's not like in the US here. You have to get the vehicle inspected the day the government chooses for you.
Old 11-09-2014, 03:53 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
I would and have removed the vac motor.
dissembled it. Cleaned and lubed it and got
them to work very well. And all the linkage
as well.
Old 11-09-2014, 04:02 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
What the Artic Y Block said: Clean and lubricate. Sometimes all they need is use. Rain X is your friend. I would ask how much vacuum the engine is pulling.
Old 11-09-2014, 07:08 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
78 & 87 Super Cab is offline
I had similar problem, except Mine would go up 1/2 way and stop
Old 11-09-2014, 09:38 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Was wondering about that. A worn out engine with a lot of blow by or maybe even one that isn't timed correctly - they wouldn't work as well would they?
My dad was old enough to have to use them when they were standard equipment and he didn't have anything good to say about them. Passing was a real adventure in the rain because flooring it means engine vac temporarily goes to nothing, and so do the wipers! I figure maybe it was another one of those sorta-works when everything is just so designs.
Old 11-12-2014, 03:14 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I have a complete stock electric set up from a '60 F350. Still in the parts truck. My son is always looking for a job, so I could have him pull it all. Send me a PM if you are interested.
Old 11-13-2014, 06:28 AM
3414's Avatar
3414
3414 is offline
On vacuum wipers, If they are not working here are a few things to try.
Trace the vacuum line from the wiper motor back, For me the systems that worked best the line went from the wiper motor to the auxiliary diaphragm on the fuel pump to the intake manifold.
To troubleshoot, take a new piece of vacuum hose and connect the wiper motor directly to a port on the intake manifold. With the truck idling turn the wiper **** to max. Make note of the speed of the wipers. Then slowly raise the engine speed to about 2500 to 3000 rpm. Then let the engine speed drop quickly to idle - the wipers should speed up, if not check for vacuum leaks. If no leaks, disassemble the wiper motor, clean and lube all parts, and reassemble and test again.
Old vacuum hoses can get soft and collapse or get hard and crack when under vacuum, so when doing any testing use a new piece. Good luck.
Old 11-13-2014, 10:22 AM
Lewis1960's Avatar
Lewis1960
@ GB SISSON, Thanks for the offer, I would love to bring your son over here to Switzerland to work on our truck but unfortunately, I can't afford it at the moment. I'm going to see if my mechanic can get the wipers going better by lubing and checking for leaks. I just got the shop manual too, so I'll see if there is any info in there that is useful. Have a great day!
Quick Reply: Vacuum Wipers slow
