Custom rear drawers (3rd row removed)
Dam that is a bit of money but looks super sweet looking. Going to be a tank when its done. I found these sliders i was thinking of using. They even have 60in http://truck-hardware.orrorr.com/ite...-slide/h-8434?
Dam that is a bit of money but looks super sweet looking. Going to be a tank when its done. I found these sliders i was thinking of using. They even have 60in Item # H-8434, Heavy Duty Full Extension Slide 250 and 500 lbs On Orr & Orr, Inc.
OK, this makes me think of something that might benefit all of us...
If everyone interested in this project (either watching or making their own variation of it) took a few minutes and tried to search for the cheapest components they can find, maybe we can make a 'best price' sheet for people to go search for items.
Someone else here already found drawer slides much cheaper than I could find them...how about if you are interested, you do a quick search for some of the components locally. For all I know, the parts I bought through Steven Engineering could be sourced for much less by some small shop in another state.
I'll start with where I found my items and the prices (admittedly all Amazon.com 'cause I'm impatient as ******)...
Drawer slides:
Drawer slides:
KV 8900 Series Full Extension Precision Ball Bearing Slides 40" 500# Class (Set)
Amazon, $179.95 for a set
Connectors:Amazon, $179.95 for a set
Amazon, 2.60 per (needed 13)
Amazon, 2.95 per (needed 9)
Amazon, 2.60 per (needed 21)
Amazon, 2.60 per (needed 22)
Amazon, 2.60 per (needed 2)
Square Tube Aluminum:
Amazon, 7.84 per 48" length (needed 29-30 depending on configuration)
Drawer Handles/Latches:
If anyone thinks they can find these items or equivalent ones for cheaper, post up where you find them.
Still need to swing by Fastenal to get some of the right size bolts/nuts.
Now that I have the L channel and measured out the larger drawer correctly, there are some new measurements:
^^Shows the left drawer at full extension (40" with the slides I used).
Thinking of adding 1.5" flat aluminum strip to the underside of the drawer top rails. Should hang over about 5/8" of an inch. This will let me slip in 1/2" ply and make the tops of the drawers so I can use them to write on, reload clips, whatever.
Thinking if I cut two sections just under 2', I could keep them at the 'back' of the drawer when not in use, then pull one out and make the drawer into a surface.
Progress...and setbacks.
So I have about 2/3rds of the base frame done...but a change to the plans that I didn't account for when cutting left me with a lot of excess, so I'm a few lengths short...so I'm on hold until more frame sections arrive.
So far I've attached the right and center sections of frame, the cross members to those sections, the uprights, and the right (larger) drawer.
Bottom frame laid out...
T nuts through the bottom of the base to anchor the base frame to the base...
Drilled and installed the uprights...then mounted the slides...
Added the L channel and mounted the drawer:
Testing the slides:
...so now I'm waiting on the top drawer frame sections:
...and a few more lengths of QuickFrame and I'll move on to the drawer faces and handles/latches.
Testing the slides:
Ran out of rivets!!!
I'd love to post progress photos, but the albums are down...again...
Let's try this:
Lower frame complete, uprights and slides attached...
Top frame pre-assembled...
Full frame attached to the base wood...
Reinforced the 2nd narrow drawer...
Bottom in the narrow drawer...some decent weight in it with the tool box...
Wide (right) drawer...front support added, bottom added...
Side sheeting applied to one side...ran out of rivets though.
Drawer diamond plate with latch inserted...will have to rivet the face to the drawer front though.
I'm doing first aid on a marathon route tomorrow, but should be able to make some additional progress afterwards.
Let's try this:
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
Damage truck
33
11-18-2017 06:54 PM
