2006 F350 Dually Rubbing/Skipping Sound during Sharp Turns
My husband and I have an '06 F350 4x4 dually that is my daily driver. I recently noticed that during sharp turns (such as in parking lots) I hear a skipping/rubbing/grinding noise and I can "feel" the noise as well. This noise occurs when turning either left or right and is always during a sharp turn (in 2WD). The only way I can describe the sound/feel is like it is in 4WD on a hard surface but not that violent. It's not the tires rubbing as I've been driving this truck for a couple of years and just recently started hearing/feeling this problem. Just replaced all 6 tires and the noise remains. To me, it sounds like the problem is in the rear end.
Any ideas?
Any ideas?
I agree sounds like the limited slip is not slipping as it should. Check the fluid you can even add some additive to it they sell it separately most quality brands of lube already have it. If it has never been serviced I would recommend draining it cleaning and inspect everything. seal it up and put in fresh lube. that would give you a chance to see if there are more than normal amount of wear or pieces of clutch material in the bottom.
