How to Check 4wd Hub Operation on Test Drive?
Test drives when looking to purchase a used F150...
What's the proper way to test the operation of the 4wd system on dry pavement while on a test ride? Want to make sure the hubs engage/disengage properly without tearing things up because the wheels can't slip. This is on the 2004-2008 vintage hubs with solenoid/vacuum hub control.
When it goes in 4L, you'll feel the driveline engaging. 4H, not so much. But to test either one, put it in 4x4 on pavement and try turning. If you feel scrubbing and an overall awkwardness to the vehicle's turning behaviour, you know it's in 4x4. The lights on the dash are also a good indication.
Remember though that to put it in 4L, you need to be in neutral with your foot on the brake.
Driving in 4x4 on pavement is a problem because the tires grip the pavement well, causing tire scrubbing and differential stress. This is perfectly okay temporarily as a test, but prolonged exposure will lower the life expectancy of your tires and driveline. 4x4 is fine whenever you are not on pavement and the ground is soft, i.e. instead of the tires scrubbing along and stressing your differentials, the ground will simply give way. Rocks, dirt, snow, mud, whatever.
