New electric cooling fans setup. (Pics)
Sized as if it were meant for a F100.
Installed in truck. Sorry about the dust. I haven't detailed the fans and housing yet.
The fans are 13" and dual speed. They are off of a Chrysler 300C Hemi. They push some major air. Hopefully this will help others with interest in upgrading the cooling system. The radiator is the standard '66 F100 core size.
Do you allow the truck to sit and idle a lot? That setup will block more air flow at 20mph & up than it will ever pull through itself.
The only time ol these trucks need a fan is when idling, because of the huge frontal opening once they are moving, no further assistance is required.
John
John
Eric; I did not compare the two but the fit and pulling power of this unit sold me. The whole assembly can be had for under $100.00!
2006-2008 Dodge Charger Auxiliary Fan Assembly - Cooling System - Dorman 06-08 Charger Auxiliary Fan Assembly - 18598-05107841 - PartsGeek
John
John
I live in Phx. and engine/engine bay heat is a huge problem when sitting at traffic light after traffic light. If my engine was stock with factory exhaust manifolds; I'd probably be fine. The fans are thermostatically controlled so they are not running at cruising speeds unless needed. I've attended hundreds of auto shows here and observed the various cooling systems used on classic cars to keep them cool here. I'd have to say that the majority of autos used for more than car shows; use electric fans here. In front of my radiator is a large a/c condenser and transmission cooler as well. I'll be the first to post if this doesn't work, but I suspect it will exceed my expectations.
I'm actually not overheating. The engine temps climb at slow city driving and at stop light after stop light here in Phx. I also run a/c. If it were a stock engine; I'm sure all would be fine with the stock cooling system.
I had an appointment with a homeowner back in the late 90s and my Taurus sat out in mid 90º temps idling with the AC on and the gauge never moved. I couldn't get over it, because the old Yorks pulled the engine so hard it would raise the temp to hot really fast on vehicles that I had owner prior.
What compressor are you running with your AC?
John
Gotchaya, The AC has to be adding to the concern. If you are running a York compressor even more strain.
John
John
When Temps are 110-115 no air is moving. City driving from light to light there isn't enough air moving to keep one of these trucks cool. Once your on open highway you don't need the fans. Unless your stuck in "Rush Hour Traffic" then you better have these fans.
I got mine through "The Fan Man" custom installed. I do feel so much better when I drive in the summer.
Good for you dsrtjeeper, keep it
Adding electric fans was the best thing I ever did. I'm in So. Cal. 40 miles north of Palm Springs. Like Az. it gets Hot. "How Hot?" Damn Hot!!
Thanks. Good to hear that the electric fans do help. Can't wait to test the setup.
I'm not sure if I understand what you are asking but; one can't run both the mechanical and electric fan. It's either one or the other. I suspect with your small six that you should be able to run the factory cooling setup.
