Modular V10 (6.8l)
Plug and Ignition Coil
Old 11-05-2014, 10:52 AM
kuneefay's Avatar
kuneefay
kuneefay is offline
Hey guys, so my 2000 2v v10 started what sounds like a miss. I don't know when the plugs and ignition coils were last changed but that's were I plan to start. Its got 160K on it. I was wondering what you guys recommend for ignition coils? I plan on running NGK iridium plugs. But would like to stay reasonable on price for the coils and being that the cheapest I can find oem motorcraft coils for is $40 per I will have to go aftermarket route. I've seen kind of mixed reviews on the accels and was wondering if there were any other options.
Old 11-05-2014, 04:01 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
I run Motorcraft plugs. I also replace all the boots and springs when the plugs get changed. I only change coils if they are actually bad. I usually buy the coils and boot/spring kits from Rockauto. I don't overspend for them and they've worked 100% for me so far on both this truck and the last one, a 97 5.4 that I had for almost 10 years.
YMMV.
Old 11-05-2014, 05:12 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
I agree with proectsho. Money is best spent on the OEM parts. Motorcraft plugs are platinum and designed to last 100k. I wouldn't change the coil until its needed. Currently at around 144k without issues.
I bought my truck with 126k and changed the plugs. Only one coil needed changed afterwards.
Rockauto always has a 5% discount code to use and they are priced well.
If you are able to go through Horizon Ford in Tukwila, WA they can provide part numbers over the phone and you could will call it to pick up or ship it.
I would also encourage you too check out this thread for some preventive work during install. Next time I do plugs I will probably use the o rings as suggested.
https://www.ford-trucks.com/forums/1...s-the-fix.html
Old 11-05-2014, 07:39 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Agree, great advice given.
Old 11-06-2014, 10:58 AM
dkf's Avatar
dkf
dkf is offline
I stick with Motorcraft coils, they just work. Though your coils may be fine. If you want Iridium plugs the Autolite Iridiums work well in the V10. I installed a set in my dads V10 and he has around 30k trouble free miles on them.
Old 11-06-2014, 03:52 PM
kuneefay's Avatar
kuneefay
kuneefay is offline
Great thanks for the input guys. I think im sticking with the NGK iridiums for plugs. I've have good results from them in my old 5.4L, and my old wrx.
Borgia
1999 to 2016 Super Duty
09-29-2016 01:10 PM
xtal_01
12-09-2015 02:23 PM
Watcher58
08-20-2015 04:31 PM
Tommy B405
08-05-2015 07:38 AM
jrw51
1997-2006 Expedition & Navigator
08-18-2009 11:46 PM
Quick Reply: Plug and Ignition Coil
