Help...Flywheel/Crank Locked-up - Ford Truck Enthusiasts Forums
Old 11-05-2014, 12:17 AM
Sean_Reno Sean_Reno is offline
Sean_Reno is starting off with a positive reputation.
I started an earlier thread about changing my clutch. Well, after removing/re-installing my flywheel...to change my pilot bearing and RMS...the flywheel and crank are locked-up...I can't turn the crank from the front crank pulley...I'm thinking the flywheel bolts are too long, but their the same ones I took out...do any or all of the bolts take a washer or??
Old 11-05-2014, 12:43 AM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Silly question..
Is the clutch installed? If so - tranny in neutral?
I assume the starter is still out?
From what I recall, the bolts are all the same size on the flywheel. They'd have to be pretty long to cause a problem I'd think
Old 11-05-2014, 12:51 AM
Yes, the clutch and starter are still out...I removed the flywheel to change the pilot bearing and rear main seal (RMS)...I needed to turn the crank for clearance when torquing the flywheel bolts down and it wouldn't turn...it turned before I re-installed the flywheel?? Are there supposed to be washers on the flywheel bolts??
Old 11-05-2014, 07:34 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Loosen the flywheel back up and see what happens.
Old 11-05-2014, 09:34 AM
Yes, the bolts are all the same length. However, I'm 99% sure once I loosen the bolts, it will free up the crank. But, why...what went wrong :?
Old 11-05-2014, 10:44 AM
KsCop's Avatar
Quote:
I know that the bolts on my flywheel (on the 4.9 new build) do not have washers. Come to think of it, I haven't tried turning the crank since I installed the flywheel.. Think I'll try that this afternoon...
Old 11-05-2014, 10:48 AM
The crank didn't get locked-up, until I tightened down my flywheel. This job is really kicking my *** :/
Old 11-05-2014, 04:49 PM
KsCop's Avatar
If you loosen the flywheel, can you turn the crank?
In looking at mine, the bolts would need to be WAY long to lock things up. Did you do anything else? Install the rear main seal?
I'd loosen it up and be 100% sure that is the problem before I started chasing things.
I know you said you are 99% certain loosening it up will allow it to turn. I'm betting it either won't, or in the process of loosening it up you'll figure out the problem.
Old 11-05-2014, 05:09 PM
I changed both the pilot bearing and rear main seal (RMS). It took me forever, just to get the flywheel lined-up and bolted down...I was able to spin the flywheel before I tightened the bolts down...I can't imagine the RMS is locking it up :?
Old 11-05-2014, 05:13 PM
KsCop's Avatar
You could spin the flywheel, but was the crank turning or just the flywheel?
I think there is something else wrong.
I know it's a pain, but loosen / remove the flywheel and try the crank
Old 11-05-2014, 05:17 PM
Yes, I could turn the crank/flywheel from the balancer. I know I will have to pull the fly back off...I'm just trying to troubleshoot a bit...before I do it.
Old 11-05-2014, 05:50 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I think the RMS is sticking out too far.
Did you pre-lube the seal?
They don't like starting dry.
Old 11-05-2014, 05:57 PM
Yep, I pre-lubed. The seal is flush with the edge of the rear surface of the block/cap. I just can't imagine that would stop the crank from turning.
Old 11-05-2014, 06:05 PM
pedant
On the 4.9 is there a spacer/dust plate that goes onto the back of the block before the flywheel is installed?
If you loosen the flywheel a bit, at what point is the crank able to rotate?
You can't hear anything rubbing or dragging when you turn the crank?
Old 11-05-2014, 06:11 PM
Right now the crank is 100% locked-up. Yes, there is a plate that goes between the fly and block...starter bolts to it.
flywheel problems dylansf23 Ford Inline Six, 200, 250, 4.9L / 300 2 04-25-2015 08:23 PM
C6 Auto Swap - Flywheel & Separator Plate BushyTea 1961 - 1966 F-100 & Larger F-Series Trucks 14 01-25-2015 08:14 PM
flywheel to crank bolt stripped out!!! rehrlich 1997 - 2003 F150 6 12-04-2014 05:05 PM
Starter/flywheel issues oneofakind97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-15-2014 09:26 PM
Help...Crank is locked-up!! Sean_Reno Ford Inline Six, 200, 250, 4.9L / 300 2 11-15-2014 11:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
