Scott's 61 F100 build.
Here are some more pic's of the engine install. The brake booster is from a 2004 crown vic with a mid 90's explorer master cylinder and a generic GM disc/disc proportioning vale.
Here is a picture of the fuel tank install.
The rear cross member need to be moved a little for the tank to fit. I also need to grind some on the frame and add some rubber strips between the frame and fuel tank to keep it from rubbing metal to metal. I also needed to cut some off of one of the cross braces on the under side of the bed so it would clear the top of the fuel tank.
Using my calibrated eye, I have about 2 1/2" between the bottom of the coil over and the rim.
dferrell5
12-18-2013 10:04 AM
MrScharfenberger
01-26-2007 01:41 PM
Micginish
11-06-2005 12:12 AM
